NI TestStand
MSIERROR 267 when installing Teststand 3.0
Previously used TestStand 2.0 and now changing to 3.0 but installing doesnt start and i think i have done everything in the readme.doc??
(3,092 Views)
The problem is probably due to a corrupted MsiInstaller. To fix this problem you need to download and run the MsiInstaller version 2.0 (See the links to find the correct version for your OS).
Sometimes, however, windows will not allow you to install the update. To get around this you need to run MsiCleanup (see link below) and then close the program without selecting anything. Now run the MsiInstaller again and it should work fine. You should then be able to install TestStand.
This could possibly affect all installers that use the MsiInstaller.
This will not work with XP however as this ships with Windows Installer v 2.0
For Win 95/98
and Me
For NT / 2000
MSI Cleanup (msicu for 95/98, and msicuu for nt/2000)
Hope that helps
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,092 Views)
