Bill,
I was able to create a basic report with one column holding the requirements and another column holding a particular attribute. This example can be expanded so that you can have additional columns for each attribute.
I have attached a screenshot of the configuration of the report to give you a basic idea. I have also attached the report. You can place the "Project Reports.xml" file in the "doc_models" subdirectory of your NIRG Project. For example, if your project is c:\projects\test.rqtf, place the xml file attached in c:\projects\doc_models\Project Reports.xml.
If I have misunderstood something or you have additional questions, let me know.
Allen P.
NI
