NI TestStand
Making a requirements verification matrix report with Requirements Gateway
Requirements Gateway has a built in traceability matrix report. I'd like a variation on that to do a verification matrix. I have attributes in my Word document that are read by Gateway and displayed as such. My trouble is customizing a report to display these attributes (verification methods,e.g, Inspection, Demonstration, Test, etc.) vs. the req. IDs, that is, a table with one column with Req. ID's and another column with the verification method attribute. I've only been partially successful in getting the attributes to show on the report.
(3,959 Views)
Bill,
I was able to create a basic report with one column holding the requirements and another column holding a particular attribute.  This example can be expanded so that you can have additional columns for each attribute.
I have attached a screenshot of the configuration of the report to give you a basic idea.  I have also attached the report.  You can place the "Project Reports.xml" file in the "doc_models" subdirectory of your NIRG Project.  For example, if your project is c:\projects\test.rqtf, place the xml file attached in c:\projects\doc_models\Project Reports.xml.
If I have misunderstood something or you have additional questions, let me know.
Allen P.
NI
(3,937 Views)
Thanks, Allen....
(3,924 Views)
