NI TestStand
Manually choosing next step to execute
Hello, im learning TestStand and right now making my first test using some labview VIs.
After some setup VIs i have 2 separated read vis (a single point and a multipoint read) and wanted to decide manually during the execution of the sequence which one i'd do. How can i do it? Tought about a message popup but i dont know how to make it so that when i click one of the buttons it executes that specific step.
Thank you
(1,135 Views)
Accepted by domcorrado
See the attached sequence file.  Just store which button was pushed into a local variable and then use that as a precondition on the other steps.
Let me know if you have any questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,099 Views)
