NI TestStand
Programmatically get version history from a sequence file with Labview.
Hi
I'm making a program that store sequence files to SVN in LabVIEW.
I want to Programmatically get version history from the sequence file.
I found this tropic How to Get Sequence File Version Programmatically in LabVIEW - NI, but I can find anything that read the version history from the file.
Is it possible to get that?
(1,528 Views)
You can look at the commands supported by SVN from command line.
Using command prompt from LabVIEW call the appropriate command and parse the return value.
Ravi
(1,497 Views)
@Ravi
Sorry, but I was probably not precise enough.
I want to get version history from the TestStand Sequence file. Not from SVN 🙂
regards Bjarne
(1,490 Views)
I don't think that is stored in the sequence file.  What makes you think it is?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,485 Views)
Version history is not stored in the Sequence file and definitely not the commits you made to SVN (only SVN knows your commits and comments)
Santhosh
Soliton Technologies
(1,480 Views)
Just to be fully sure.
I'm new to TestStand so maybe I'm using the wrong words for what I want to achieve.
When I save a new version of a sequence file in TestStand, I can write a comment about the change I have made.
Is this comment not stored in the Sequence file?
(1,467 Views)
