NI TestStand
Manually choosing next step to execute
Hello, im learning TestStand and right now making my first test using some labview VIs.
After some setup VIs i have 2 separated read vis (a single point and a multipoint read) and wanted to decide manually during the execution of the sequence which one i'd do. How can i do it? Tought about a message popup but i dont know how to make it so that when i click one of the buttons it executes that specific step.
Thank you
(1,127 Views)
Accepted by topic author domcorrado
See the attached sequence file.  Just store which button was pushed into a local variable and then use that as a precondition on the other steps.
Let me know if you have any questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,091 Views)
