NI TestStand
.NET Framework 2.0 Service Pack 1 Breaks Variables View and Insertion Palette
Today, Microsoft released .NET Framework 2.0 Service Pack 1 as a critical update via Windows Update.
SP1 breaks the TestStand Variables View and Insertion Palette on custom User Interfaces.
Please read this KnowledgeBase for more information
Josh W.
Certified TestStand Architect
Formerly blue
(4,310 Views)
Hi Josh W.,
So is the current solution not too upgrade to NET Framework 2.0 SP1 until NI has a fix?
Regards
Ray Farmer
Regards
Ray Farmer
(4,287 Views)
Ray,
That is correct.
To clarify: this issue only affects the variables view and insertion palette in User Interfaces, not in the Sequence Editor.  So if you have either a production machine using these controls in a UI, or are working on a UI on your development machine, we recommend you do not upgrade at this time.
The problem does not affect the Sequence Editor, so if you are doing development of sequences, but not of UIs, you will not experience trouble, and so are free to upgrade.
We are working on the patch for this issue, and I will post here when it is available.
Message Edited by Josh W. on 01-28-2008 09:33 AM
Josh W.
Formerly blue
(4,275 Views)
To add my own experience with this, SP1 (as Josh indicated) is part of Windows Update.  All of my development team was updated through this, and the only way to "uninstall" it is to completely remove the 2.0 .NET Framework and reinstall the base version.  You cannot (to my knowledge) just remove the Service Pack.
(4,245 Views)
