NI TestStand
NIRG Current Version
We have version 1.0 of NIRG.  What is the current version?
Also, in the 'overall' product information, it says that it has support for Windows 7
  • Support for Windows 2000/XP/Vista/7
However, in the DataSheet, it says
  • Windows 2000/XP
Just trying to make sure it will be compatible with our Windows 7 system. We're possible going to use LV2009 SP1 and TestStand 4.2, OR LV2011 and TS2010.  Any thoughts on all of this?
(3,126 Views)
https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
Looks like 1.1 is the oldest version of NIRG "officially" supported by Win 7.
Which "'overall' product information" are you referring too?
In our org we pick a developer suite and use it for a couple of years.  Then everyone upgrades at the same time.  This way you don't have issues with code reuse.  So whichever versions of TS and LV are in the same Dev Suite then that's what I would choose.  If you are upgrading to Win 7 then you should choose one with both LV and TS being supported officially.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,122 Views)
