New Login while Sequence is running
Hello Norbert,
problem solved, i found what you said.
I justed created the method "Login" with the reference from ApplicationManager and then a new login-mask appears.
This is what i wanted to have.
(If i execute a Logout then TestStand says "You have incomplete executions... ", but i dont need to Logout if i can run a new login.)
Perfect.
Thx to everyone.
Message 11 of 14
(1,258 Views)
OnlyOne,
the button is disabled and greyed out by TestStand itself because you would run into problems as stated the post before.
To get around this, you have to connect the button with another function from the TestStand API. In order to do that, you have to open the "Simple OI - Configure Application Manager.vi" and change the setting like seen in the screenshot below to CommandKind_Login. Currently, it should be configured to CommandKind_LoginLogout.
But please note that relog antoher user during execution of a sequence can lead to problems in the execution. So it is not recommended.
hope this helps,
Norbert
Message Edited by Norbert B on 09-21-2007 06:47 AM
Norbert
Expert: Geometry
Message 12 of 14
(1,262 Views)
Thx for the detailled help.
One more thing: Is there a flag somewhere in TestStand that indicates, that the user-login has changed?
I found "StationGlobals.TS.LastUserName" and "StationGlobals.TS.CurrentUser.LoginName" but they are always equal?
I mean, how do i know that someone pressed the Login-Button and the user has changed?
Message 13 of 14
(1,248 Views)
OnlyOne,
there is no function like this in TS itself. But you can implement this quite easily in the UI on your own.
Tip: Shift register for LastUser.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 14 of 14
(1,245 Views)
