NI TestStand
New UUT report for each test socket
HI !
I want to create a New UUT report for each test socket i test .
I am using TS 4.2 and testing 30 UUT in Batch Mode Each one in Different Socket .
I know there is an option in the Report Options for New UUT report for each test socket But it's Dimmed !
Maybe there is a var , controlling this option ?
Thank U , Kobi
Kobi Kalif
Software Engineer
(3,537 Views)
Accepted by Kobi_K
Kobi,
please remove the check mark in the box "Store UUT Report in Batch Report File". Then you should be able to check the other boxes you are interested in....
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,532 Views)
Thank u !!!
I'v tried each option except that 🙂
Kobi Kalif
Software Engineer
(3,525 Views)
