Not all the test in the report
Hello to everyone!
I've been checking different options of the TestStand 4.2, to check these options I go to the menu: Configure >> Report options...
My problem is that I have a test with 8 steps (some of them are subsequences others are only a VI...) and what I want is to get a report with only the result of 3 steps (not all the test).
Is there any place where I can select the steps that I want to be recorded in my report?
I'm using TestStand 4.2 with Labview 8.2
Thanks to everyone!!!
Much thanks for your time and dedication!
(2,948 Views)
Accepted by Output
For each step you no longer want to get the results for, uncheck the "Record Results" option on the Step Properties.
(2,946 Views)
Dont forget to leave the SequenceCall "Record Results" checked otherwise you will not get the results from the steps within the SequenceCall.
Regards
Ray Farmer
(2,942 Views)
Thanks to the two!
You were right!
(2,936 Views)
