NI TestStand
PXIe 4139 Source Adapt Settings VI
I am trying to configure the Source Adapt settings on the PXIe 4139 Power Supply to automate some loops in TestStand. Is there a LabVIEW VI that I can use to configure these settings or is instrument studio the only way?
Thanks.
(1,051 Views)
first of all, I guess you should post your question here https://forums.ni.com/t5/PXI/bd-p/270
Having said this: if you haven't found any VI in the NI DCPower palettes in LabVIEW, check the Example Finder in LabVIEW.
If there is no VI, check connect a Property Node or Invoke Node to the DCPower session wire and see if you can find anything suitable there
Oli
(1,011 Views)
