Parrallel testing using rentrant VIs with Funtional Globals
I belive that in order to run a vi in parallel in teststand you must make it reentrant.
My problem is that one of my VIs uses a functional global and I don't want it to effect the other VIs ran for the other test sockets.
What is the best way to handle funtional globals in a parallel or batch process model?
Also is there a way to have Teststand handle whether or not the VI is reentrant?
Glenn Ellis
(4,198 Views)
make the functional global also re-entrant
(4,188 Views)
Making the Funtional Global reentrant won't work since it will just creat a copy every time it is called.
Glenn Ellis
(4,175 Views)
Accepted by topic author glennjammin
Greetings,
The difficulty here is that you're basically looking for a way to limit the scope of a global variable. What if you converted your functional global variable from a single value, to an array? You could then index based on what test instance you're working on. Essentially you'd still be talking to the same global variable, but you'd have uniqueness in the index of the array. How does that sound? 😄
Product Support Engineer
(4,163 Views)
Here is an example of the solution:
Functional Global:
Glenn Ellis
(4,130 Views)
I think you missed the attachment
(4,117 Views)
Here they are
Funtional Global VI:
Reentrant VI
Glenn Ellis
(4,111 Views)
