NI TestStand
Password not required when adding callback from locked processModel
Hi all,
We locked a Model sequence with a password.
It appears that the password is not required when adding a callback to a sequence file that uses the locked model, so the copied callback becomes visible.
Is there a reason for that ?
I think if the model is locked, the password should be required to copy a callback.
Thanks and Regards
Cordialement,
Micaël DA SILVA
(2,525 Views)
Accepted by Micael_
Is your concern with allowing the callback to be overridden or just the copying of it's contents? You can disable the latter on the sequence properties of the callback:
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,503 Views)
Hi Trent,
Many thanks, that is exactly what I needed to do.
Best Regards.
Cordialement,
Micaël DA SILVA
(2,154 Views)
