05-02-2019 09:28 PM
I am trying to open a TestStand sequence developed in TestStand Version2013 and LabVIEW Version2015. When I open a sequence in teststand, in TestStand Version2017 and with LabVIEW version2018 it is asking to reload the VIs. It showing exclamatory mark even though I load/provide the path for the VI. The same is happening even if I save the VIs in LV2018 and load in Teststand. Provide me a solution.
Solved! Go to Solution.
05-03-2019 03:43 AM
What do you mean with "showing an exclamation mark"? Are the VIs "not found"?
If so, my guess is that you had a search directory configured in your previous TS version which you haven't in the new one...
05-03-2019 04:10 AM
Yeah...VI not found. Also I have added the folder path to the search directory. I have done update VI calls also
05-03-2019 04:19 AM - edited 05-03-2019 04:20 AM
Never seen TestStand to fail to find modules if search directories are configured correctly. Make sure that your entry fits to the relative paths of the modules.
Example:
Search Directory:
C:\temp
Relative Paths:
Modules\DAQ\AI.vi
Modules\DAQ\DO.vi
This will find both VIs if they are located in C:\temp\Modules\DAQ\ each.
If you configured the Search Directory to:
C:\temp\Modules
TestStand will not be able to find the VIs as they are searched for in C:\temp\Modules\Modules\DAQ....
Also make sure that the search directory (if correct) is enabled by making sure that the checkbox is marked.
EDIT: Another item might be "Include Subdirectories" checkbox...
05-03-2019 06:12 AM
Some of the VIs are loaded automatically and some of them didn't. But it is ok that it is loading when I provide path. Thank you Norbert.
