NI TestStand
Problem inserting image into Test report
Working on a little test sequence and ran into a minor issue when inserting an image into the TestReport. The image appears fine, but is there a fairly easy way to change the "Report Text" to say something else? I tried Step.name, but that does not work. I have included the code in Post expression for reference. Thanks....
Dan
(3,017 Views)
Hi Dan,
The easiest option would be to move this out of the Expressions area and insert it using Additional Results.
This way you can name the Result however you want instead of using the ResultText. I've attached an image showing where this can be done. You can set the Name to be any String you need, and then specify the Value in the same way you did in the post-expression.
Nico
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(2,961 Views)
Hi Nico,
     Thanks for the help. Unfortunately I do not seem to have an option "Step Image" in the drop down pick list. Is there a way I can add it? Forgive my ignorance. 🙂
Dan
(2,949 Views)
Hey,
Sorry, that was my fault. There isn't one in the list. On the right hand side, select Add Custom Result. Then you can manually add any name you want for the Result.
Nico
Nico
Systems Engineer
(2,915 Views)
