08-01-2017 03:59 PM
Working on a little test sequence and ran into a minor issue when inserting an image into the TestReport. The image appears fine, but is there a fairly easy way to change the "Report Text" to say something else? I tried Step.name, but that does not work. I have included the code in Post expression for reference. Thanks....
Dan
08-02-2017 04:09 AM
Hi Dan,
The easiest option would be to move this out of the Expressions area and insert it using Additional Results.
This way you can name the Result however you want instead of using the ResultText. I've attached an image showing where this can be done. You can set the Name to be any String you need, and then specify the Value in the same way you did in the post-expression.
Nico
08-02-2017 11:07 AM
Hi Nico,
Thanks for the help. Unfortunately I do not seem to have an option "Step Image" in the drop down pick list. Is there a way I can add it? Forgive my ignorance. 🙂
Dan
08-03-2017 09:59 AM
