06-15-2021 10:48 PM - edited 06-15-2021 10:49 PM
Hi NI Community,
I am currently creating/developing an RF Power and Frequency Sweep for my UUT. At the moment I am trying to test how to manually use the RF source and receiver using our tester and as I manually do this I encounter this selection (Image attached).
Actually I tried selecting each of it and no error occur. I just wanted to know the difference of each and the proper file to be selected. Since, while allocating resources from my pin map this selection also appears when I set-up my VST resource (PXIe-5646R).
Solved! Go to Solution.
06-16-2021 05:51 AM
When using a VST, just use the NI-RFSG for the generation. I like to use RFmx for the receiver, which is a useful library used on top of NI-RFSA.
06-21-2021 10:57 PM
You should be selecting NI-RFIC if you want to control the RFPM (Port Module), in RF STS setup, you would always have Port module with VST and hence you should always use the NI-RFIC as bitx file for the VST (RFSG and RFSA).
