NI TestStand
Reading Configure->Station Options->Immediately Goto Cleanup on Sequence Failure Checkbox Setting
In TestStand 3.5, how do you programatically read the status of the Configure->Station Options->Immediately Goto Cleanup on Sequence Failure checkbox?  How would you programatically set this value?
(3,828 Views)
Accepted by rw1dale
Engine.StationOptions.AlwaysGotoCleanupOnFailure
(3,817 Views)
Thanks for the reply, but I tried your suggestion and it cannot resolve the reference.  When I typed in Engine. it was immediately replaced by RunState.Engine. so I used RunState.Engine.StationOptions.AlwaysGotoCleanupOn Failure.  When the step was executed, there was an error stating "Unknown variable or property name RunState.Engine.StationOptions".  When I go to the context tab, I see the Engine object, but I cannot expand to see what elements it contains.  Any further suggestions?   How does one find out what "Engine" contains anyway?
(3,798 Views)
Thanks for the suggestion.  After reading up a bit on the TestStand object model, I was able to utilize the ActiveX/COM adapter to get the property information I needed.
(3,794 Views)
Sorry, I should have said you need to use the ActiveX adapter in 3.5. In 4.0 and beyond, you can also use an expression to access the TestStand API.
(3,791 Views)
