NI TestStand
Reading UI messages in the SequenceEditor from a second parallel sequence
Is there a way to read the UI messages from a running sequence in the SequenceEditor in another sequence (in a new thread)? I've tried different scenarios, but unfortunately I didn't make it. Can anyone help me further?
Thanks in advance...
(2,160 Views)
Accepted by T.
This is doable but highly highly discouraged.
I've thrown together an example in TS 2017 and LV 2017.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,128 Views)
Forgot to mention.
You HAVE to have something that can capture events.  So a pure TestStand solution is not possible here.
jigg
CTA, CLA
testeract.com
(2,126 Views)
Hello, thanks for the example. It looks good at first. So far I didn't know how to get to the ApplicationManager. I will test it and report again here.
Thank you first ...
(2,119 Views)
I integrated it into my application and it works fine. Thanks a lot for the example.
(2,005 Views)
