Refresh all labview calls in a Sequence file after VI change
I am not sure if this is how Teststand is supposed to work, or is there a workaround for this.
I have a VI that I eventually add enumerated values to a drop down list on the front panel. When I do so, then I will not be able to run any sequence that calls this VI unless I reload the VI. This will not be a problem if I have to do it once or twice, but I am using this VI all over the place and it becomes tedious in this case.
Is there a better way to automatically update all the VI calls in a sequence file at once ?
Sam
Message 1 of 10
(5,843 Views)
Have you tried Tools >> Update VI Calls... ?
You should be able to update the enum by setting the "Reload Prototype if Changed" checkbox.
Message 2 of 10
(5,838 Views)
Accepted by OpenECU
Older versions of TestStand do not contain the Tools -> Update VI Calls... feature.
See the following instead...
http://zone.ni.com/devzone/cda/epd/p/id/5267
PH
Message 3 of 10
(5,830 Views)
Thanks. The >Update VI under >tools worked just fine.
Message 4 of 10
(5,801 Views)
I have TS 4.2.1 and don't see the Tools-> Update VIs option.  Am I missing something in setup?
Message 5 of 10
(5,788 Views)
It should be under Tools > Update VI Calls. I have the same TS version. Maybe the tool is missing from your installation.
Message 6 of 10
(5,783 Views)
Is "Update VI Calls.." available on a deployed version?
hello from chicago
Message 7 of 10
(5,722 Views)
Hi hellochicago,
I beleive this depends on which UI you are using to run the sequence.  Why are your VIs changing on your deployed system?  It may be possible to use the programmatic method mentioned above.
Message 8 of 10
(5,700 Views)
Michael W,
I thought that once a test application has been deployed with TestStand along with source module VI's, I could update individual VI's on deployment target without going through TestStand deployment utility.  I thought I could simply copy the updated VI's to the target folder that contains source module VI's.  This turned out to be not true.
This article says the deployment utility does more than simply copying VI's (http://digital.ni.com/public.nsf/websearch/49A380D75C705AE1862575DB0005503D?opendocument&Submitted&&node=133020_US ).  Therefore my concept of updating VI's on target machine by simple file transfer would not work because TestStand would lose dependencies information between test sequence and VI's (and their sub VI's).
Would test sequence still run on deployment machine if the change in VI is limited to code inside the VI (meaning, inputs and outputs don't change)?
Steve
p.s. I was going to start a new thread with my question but I explained here since you asked why I would update VI's on deployed system.
Message 9 of 10
(5,694 Views)
Hi Steve,
I don't beleive you'll be able to just copy VIs over, even if the inputs and outputs remained the same.  Every reference in a SubVI is rewired as it states in the KnowledgeBase you mentioned.  Therefore, if your VI calls any SubVIs, the deployement utility will have changed these references which means replacing a VI directly will break the chain.  However, I'm not completely sure if this applies to all SubVIs or just your SubVIs.
Message 10 of 10
(5,644 Views)
