NI TestStand
Result in report only for sequences
Hi all
I have 4 sub sequences( Test Structure A-D)  in a Main sequence. And each 4 subsequences have different number of steps inside it. I just want to have the result of only these 4 subsequences in the report, with the Sequence name with it.
Like " Test Structure A : PASSED"
Program looks like this :
Setup
Main
Test Structure A
Test Structure B
Test Structure C
Test Structure D
Cleanup
is there a way to add PASSED/FAILED in report with the subsequcne names on them?
Nghtcwrlr
(934 Views)
Please check the attached sequence.
It only prints sequence name and its results.
I have disabled result logging for each steps in the sequence call.
Run this sequence as a single pass.
Ravi
(825 Views)
