NI TestStand
RunState.Root.RunState.InitialSelection.SelectedSteps[0]) gives error
HI,
I use the following precondition for running SinglePass (one or few steps selected).  However, in Run UUTs (full test mode) I get an error (pre condition can be evaluated...)  since the value of this field is empty.
RunState.Root.RunState.InitialSelection.SelectedSteps[0]) != "DATA Test"
Any suggestions how to make the Run UUTs ignore this precondition?
Rafi
(2,982 Views)
Try using GetNumElements(RunState......) if the value returned is 0 then the array is empty.
Regards
Ray
Regards
Ray Farmer
(2,964 Views)
