I need help with the configuration for an SQL database.
When I check the connection in Configure → 'Result Processing' → Database → Options --> Build/DataLink Properties --> Test Connection. Its succeded.
But when I run my sequence, I get the following error: -2147217900. Could not find stored procedure "InsertUUTResult".
Please attached, you can see photos of the error.
Could you please help me with this?
Thanks so much in advance
