Search-replace functionality in custom sequence editor
Hi
I use custom sequence editor on my production machine.
Sorry, it does not provide any search possibility in a opened sequence file.
Can I add such possibility to the cusstom editor from TS ActiveX API?
Or is there another way?
I have only custom editor license on my production machine.
Thanks in advance
(3,084 Views)
Accepted by anpis
Hi Anpis,
What type of search would you want to perform within your sequence file?
Have you seen the Search method in the TestStand API Help?  You may also find some useful information in the API Reference.
Let me know if this helps,
Warm Regards,
Daniel Dorroh
(3,062 Views)
Hi, Daniel
Thanks a lot for your information.
It may be the real solution.
I supposed there is a some ActiveX dialog or external module which may be used as ready for use component.
Ok, I am ready to spend time for low level work to recreate this mechanism myself.
Thanks once more.
My question is closed
(3,048 Views)
