Sequence Context vs. Parameters
What is the best/most efficient way of communication with a VI and why? Passing down the Sequence Context, or passing parameters directly to the VI controls?
Chris
(5,310 Views)
Chris,
there are two situations where you might want to use the SequenceContext as parameter (and use get/set property for data exchange) over direct parameter passing:
1) You inherit code from TS 1
2) You want to exchange more than a dozen of parameters, but, for whatever unlogical reaon, you are not willing to create nice data structures (=> clusters) out of those parameters
That being said, passing parameters directly is superior in nearly every aspect.
Norbert
Norbert
Expert: Geometry
(5,306 Views)
Hi Norbert,
With TS 1 are you referring to a specific version of TestStand?
"That being said, passing parameters directly is superior in nearly every aspect."
Can you elaborate on this a little?
Chris
(5,303 Views)
Accepted by chris86
Chris,
yes, i refer to TS version 1 as in that version, it was the only way to pass parameters to LV code modules (i think in TS 2 as well, but i am not sure which version brought the "generic parameter passing").
Well, what should i elaborate? Direct parameters are faster, more secure, improve modularization and debugging (you can test your VI outside TS, no?) and create much better readable code. There are for sure additional things i forgot about.....
Norbert
Norbert
Expert: Geometry
(5,301 Views)
