Hello
I am modifying an TS 3.1 Operator Interface using LabView 7.1, right now I am trying to modify the SequenceView Control adding 2 more columns to show to the user the tests specs (maximum and a minimum) of the running sequence steps.
I have these specs data whithin a container in  my file globals (which I download from a server, so I have no control over them). This is
StationGlobals.Test[0].Min
StationGlobals.Test[0].Max
StationGlobals.Test[1].Min
StationGlobals.Test[1].Max
and so on...
The problem I am dealing with is passing these values to a "Expression Column" because the steps are not always actual tests (they may be popup msgs, actions, etc.) so the specs indexes always differ from the step indexes (THIS IS EXPLAINED IN THE ATTACHMENT). I have been able to get the StepType (Typeof(Step)) and apply an "N/A" label to a non-test step, I actually have a counter which indicates me the number of the test-step thus I can update the spec, the only problem is that when this occurs the whole column updates at once. Is there a way to get the index data from the "Index Column" so that I can use it in the "Expression Column" ?? Do you have any suggestion???
Thanx in advance for your help
