NI TestStand
Set Step.Limits with ActiveX
I am working on developing a VI to create a TestStand sequence based on a given set of inputs from an excel file.
Through LabVIEW I have been able to create a new sequence file and insert a "LabVIEW Numeric Limit" test into the sequence (VI attached for adding new numeric step). I don't know how to take this further and set numeric limits "Step.Limits.Low" & "Step.Limits.High"
Appreciate if someone can let me know if/how this is possible.
Thanks & Regards,
Don1
PS: Please advise if I should have posted this on the LabVIEW board.
(3,110 Views)
Accepted by ShaneDonn
Using the Step Reference change it to a PropertyObject reference (Step.AsPropertyObject), then you can change the default values using the PropertyObject.SetValNumber using the Lookup String for "Limits.Low" and "Limits.High".
Regards
Ray Farmer
(3,105 Views)
Hi Ray,
Thanks for the fast response - I tried your suggestion but can't seem to find "PropertyObject.SetValNumber" - I must be setting this up wrong?
Screenshot attached.
Thanks & Regards,
Don1
(3,098 Views)
Hi Ray,
I just found what I was doing wrong!
Don1
(3,095 Views)
