NI TestStand
Show PreUUT steps in the TestStand SequenceView UI Control
I have a custom PreUUT callback sequence.
I use the SequenceView UI Control (ActiveX) to display the test progress. It shows the test steps correctly, but it stays blank while the PreUUT is running. Is there a way to show the PreUUT steps in the SequenceView?
Certified LabVIEW Developer
(2,425 Views)
Accepted by JKSH
For whatever reason it looks like the engine changes the tracing settings each time a step executes.  I tried to put a step at the beginning of setup to turn on tracing but it gets turned off immediately.
As a hack I added the SequenceFilePreStep callback and put RunState.Caller.RunState.Tracing = True in a statement step.  I don't like it but it works.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,373 Views)
It does feel wrong, but I havne't been able to find any other way.
Thank you for a working solution!
(2,344 Views)
