Sort array in TestStand
I have an array of custom type container, something like:
- TestName
- Type
- Operation
I'd like to sort this array by Type and Operation.
Is that possible in TS 2010? If not - what is the best way to do that? I'm using also LabVIEW and C/C++.
Thanks in advance
(3,814 Views)
Accepted by Berezka
In this case I would recommend passing it to LabVIEW and let LV handle the heavy lifting: http://forums.ni.com/t5/LabVIEW/Sort-1D-array-of-clusters-by-the-second-element-in-the-cluster/td-p/...
Check out Darren's post.  It's a clean sort of clusters.
TestStand isn't designed for complex algorithms.  Although you could probably do it in TS you would have to come up with the algorithm.
Cheers,
jigg
CTA, CLA
testeract.com
(3,806 Views)
jigg,
Thanks a lot!
(3,783 Views)
