NI TestStand
Standard Named Data Types
Where I can find list of all the built-in Standard Named Data Types defined in TestStand?
I found only these:
  • Error,
  • CommonResults,
  • Path,
  • Expression,
  • NI_TDMSReference,
  • NI_UserCustomPrivileges.
But the way help topic mentions it, might suggests there are some more.
I would like to know these names to make sure I don't create types with reserved names.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,246 Views)
Accepted by bienieck
HI,
First open Configuration -> Station Options -> Preferences -> click Show Hidden Properties.
Then you should open the Types view, there NI_types.ini.
In there (or other ini) you find the standard data types.
CsBihacker
(2,163 Views)
