Step That Caused UUT to Fail
Can anyone tell me if TestStand stores the step that caused the UUT to fail anywhere that is easy accessibly in the PostUUT loop?
Thanks & Regards,
Shane.
(3,566 Views)
Hi Don1,
You can't directly access the failed step in the PostUUT loop but what you can do is use the "SequenceFilePostStepFailure" callback, which gets called on every step failure. You can then save the Step in a fileglobal variable at that point and then subsequently access the variable from the PostUUTLoop callback.
Raj
(3,538 Views)
Thanks for the fast reply.
I have added "SequenceFilePostStepFailure" but I am not exactly sure where to grab the name of the failing step from once inside this sequence.
Is it somewhere in RunState?
Shane.
(3,530 Views)
Accepted by ShaneDonn
Hi Shane,
It's under Parameters.Step.Name inside the SequenceFailPostStepFailure callback.
Raj
(3,528 Views)
