‎07-15-2008 02:20 AM - edited ‎07-15-2008 02:21 AM
‎07-15-2008 09:23 AM
‎07-15-2008 12:58 PM - edited ‎07-15-2008 12:59 PM
‎07-15-2008 03:00 PM
Hi Josh,
Thanks.
I should have carried on to the next chapter as I found the Note that said it was hidden.
Note
By default, the Sequence Adapter is hidden in the Adapter ring control. To enable it,select
Configure»Adapters from the TestStand menu bar and remove the checkmark fromthe checkbox in the Hidden column.
Regards
Ray
‎07-15-2008 03:11 PM
This is an extract from the Reference Manual.
You can use the Sequence Adapter with other step types, such as the
Pass/Fail Test or the Numeric Limit Test. Using a Sequence Call step is the
same as using an Action step with the Sequence Adapter except that
the Sequence Call step type sets the step status to Passed rather than Done
when the subsequence succeeds. If the sequence fails, the Sequence
Adapter sets the Sequence Call step status to
Failed. A sequence fails ifthe status for a step in the sequence is
Failed and you enabled the StepFailure Causes Sequence Failure option on the Run Options panel of the
Step Settings pane. If a run-time error occurs in the subsequence, the
Sequence Adapter sets the step status to
Error.
Regards
Ray
‎07-16-2008 01:38 AM
Hello Josh,
This must have been something that was introduced in TestStand 4.1 because it was unhidden in TS4.0 and below.
One wonders why!
Regards
Ray Farmer
‎07-16-2008 03:57 AM
