Step comment height
Hi, dear ALL
I have a small question. By default the height of step's comment is limited with 3 strings. How to modify this value? I can't find the appropriate option =(
Max
(3,392 Views)
Accepted by maksya
Max,
if you are working with TS 4.x, rightclick the Step List to open its configuration. Press "Edit..." to open the config dialog. In the first, active tab you can see an entry "Comments Lines to display". The default value is 3.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,388 Views)
Thank you, Norbert! It works. The upper limit is 5, but nevertheless 5 is better then 3 😃
Max
(3,383 Views)
