Syntax Error while using FindIndex in TestStand Functions
Hi All,
I used this function long before which was working for me, but not sure what i am doing wrong not able to get my work done.
This is my scenario,
I have a Local variable  1D array of String assume (Locals.XXX)
i need to get First element value
I used the Below syntax
FindIndex(Locals.XXX,1,True)
Advice me what i am doing wrong
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 1 of 9
(7,655 Views)
Hi Palanivel,
Is the array an array of strings?  Perhaps you should use
FindIndex(Locals.XXX,"1",True)
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 2 of 9
(7,652 Views)
I tried this but i am getting Empty value instead of 1st Index Value
Message 3 of 9
(7,647 Views)
The FindIndex function returns the index as a string, formatted as "[i][j][k]"; are you trying to use this or are you expecting a numeric index to be returned?
To get a numeric index, use the following expression:
IndexToOffset(Locals.Array, FindIndex(Locals.Array,"1",True))
Message 4 of 9
(7,643 Views)
Hi Charlie
Thanks for the update,
I need the Index Value assume My Locals.Array contains values as ["asd","fgh","jkl","qwe","rty","uio"]
If my index value is 1 then i need the output as "fgh"
Message 5 of 9
(7,638 Views)
Hi Palanivel,
See the attached example.
Message 6 of 9
(7,636 Views)
Hi Charlie
Its Working Vice Versa i can able to retrive my index for my Index Vaue  which is same as Search 1D Array in labVIEW Functions.
My requirement is to work as same as Index array in labVIEW
Message 7 of 9
(7,632 Views)
Accepted by PazhanivelVenkatt
Thanks Charlie
I will use an alternative Method for the same requirement
Locals.MyArray[4] instead of Find Index
Kudos to your support!
Message 8 of 9
(7,610 Views)
No problem - glad I could help!
Message 9 of 9
(7,606 Views)
