The VI which is creating that error is the first one in your sequence which is going to be loaded/executed? What happens if you try to execute the modules in the LV Developement System?
I asume that UI and modules are not compiled in the same version of LV which can lead to such issues...
hope this helps,
Norbert
Message Edited by Norbert B on
11-14-2007 03:26 AM
Norbert
Expert: Geometry
