TTCn and TestStand
Has anyone ever used TTCN with TestStand?
thanks
Mathieu Bazinet
(3,472 Views)
I haven't used it or even heard of it before but did a quick search and found a bit on TTCN-3 FX which uses .NET therefore you could use the .NET adapter in TestStand
http://ttcn-3.net/index.html
Regards
Ray Farmer
(3,467 Views)
also found this
http://www.testmart.com/webdata/mfr_pdfs/ANRI/PTS_VST_Datasheet_RevA.pdf
so the answer is YES, Anritus
Regards
Ray Farmer
(3,464 Views)
yes I found that one too. I guess I just wanted to hear someone's day to day experience with the 2.
cheers
Matt
(3,461 Views)
