TestStand 2013: Pop-Up Hangs after Pressing Buttons
When using the Message Pop-Up Included in TestStand 2013, the application can occasionally hang/freeze after any of the buttons on screen are compressed (see photo below). Only pressing the 'x' button to close the window allows me to move on with the test; any thoughts on why this occurs? The pop-up is modal and this issue only happens from time to time. I do have a post expression and post action for this step, so I've included pictures of those in this message as well for reference. About 90% of the time pressing 'OK' works just fine, it's only every so often that compressing the button causes the entire pop-up to hang. When it does hang, the other button (abort in this case) can still be compressed as well, but it also compresses fully without actually doing anything.
Thanks for your help!
Message 1 of 1
(1,013 Views)
