TestStand 2014 TestExec.ini reference manual?
Hi, does anyone know where I can find a reference manual for the TestExec.ini file? I need to understand some commands and their syntax:
LastWorkspaceOpenedPath
ReloadDocsWhenOpeningWorkspace
ReloadLastWorkspaceAtStartup
ModelsMRUList Line0001
ExpressionBrowserDialogSize
StationModelPath2
AdditionalResultsSettings
etc, etc...
(4,071 Views)
No such thing exists.  You are one version too early as well.  In 2016 they got read of testexec.ini and broke it out into the appropriate cfg files.
It seems that testexec.ini was sort of a catch all for settings that didn't fit in other cfg files.  For instance it contains station options, search directories, etc...
Is there a specific problem you are trying to solve by understanding these things?
jigg
CTA, CLA
testeract.com
(4,034 Views)
Thank you for the reply jiggawax (cool name).
First; What is in 2016 is irrelevant to this discussion, unless there is documentation for that version and it covers these commands.
I really appreciate your response, and thank you for the help, however there has got to be some documentation somewhere that explains the different commands and how to use them. Perhaps this is not a public document, but I really cannot believe that the Testexec.ini file has a command set that is not documented.
I do not mean to question your authority but are you a National Instruments representative that knows for a fact that "no such thing exists" or are you just speculating? Perhaps it is simply not a public document?
These commands have got to be documented somewhere.. how did someone know how to use them in the first place?
[__Header__]
ProductName = "TestStand"
ProductVersion = 14.0.0.274
CompatibleProdVersion = 14.0.0.0
Version = 773
Type = "TEConfigFile"
Path = ""
ProductVersionString = "2014 SP1 (14.0.1.103)"
CharEncoding = "SBCS"
[DEF, %OBJROOT]
Config = Obj
Expression = ExprValue
Path = PathValue
[DEF, Config]
UIMsgDelay = Num
UpdateExternalEnvironments = Bool
SearchDirectories = Objs
PromptToFindFiles = Bool
StationID = Str
NumStationGlobalsBackupsOnStart = Num
NumStationGlobalsBackupsOnSave = Num
_AdapterCfg = Obj
ExceptionDetails = Bool
RecordResults = Bool
StopOnSequenceFailure = Bool
RecordResultsForInteractiveExe = Bool
RunSetupCleanupForInteractiveExe = Bool
EvalPreconditionsForInteractiveExe = Bool
PropagateStatusForInteractiveExe = Bool
(Just the first group of lines, but you get the point)
(4,029 Views)
Accepted by Br0ce77
You are correct.  I was just pointing out that if it is an option for you to update to 2016 then I'd consider that because the settings in TestExec.ini are broken out in a more related manner.  If it's not an option then I understand.
I am not a representative of NI.  I was under the assumption that by posting in a public forum you were asking if this documentation was made available publicly.  And although I haven't read everything on the internet I have read about 99% of the TestStand related information.  There is a 1% chance I missed where the TestExec.ini file was documented in a public manner and to the level you are asking.  Also, there is a 100% chance I like to make up statistics... 🙂  Let me re-phrase my initial post: "I haven't browsed upon any public documentation about TestExec.ini to the level you are looking."  The closest I've seen is found here:
TestStand App Data And as you can see- it only talks about what is stored inside of the config files at a high level.
In the 2016 manual it gives a little bit of insight into the 2014 version of the file: "TestExec.ini was a hybrid of a plain INI file and a PropertyObject file stored in INI format."  So if you are familiar with both formats then you could potentially go through it and intuitively figure out what those things are.  Another thing you could do is look at the items in the file and derive which class it could be related to.  For example if you see the word: RecordResults then you can assume that is related to Station Options because that is an option in Station Options.  Therefore you could go look at the help about the API for Station Options and determine the type for RecordResults.  I've made it easy for you: Click Here This outlines the class for StationOptions and its related methods and properties.
The reason I asked why you needed to know this information is because generally when someone needs to change something in this file they go through the API.  I could help point you toward the correct API methods depending on your needs.
Let me describe some things I do know about the file:
-It is generated by TestStand if it doesn't exist in the simplest form.  You can go delete it, restart TestStand and see the bare bones of what TestStand expects from this file.  Note that default values will not exist in this file (or any PropertyObject file for that matter).
-The file changes depending on what you do in TestStand.  So if you change StationOptions then the file will get updated.  Therefore it is not worth trying to manage the file through the API if others can simply change it the native way (i.e. a dialog provided by the sequence editor or the user interface).  This is, of course, unless you have other motives.
-Most of the items can be accessed through the TestStand API.  Which are documented.
-You should always use different settings in the file for a development PC vs a deployment PC.  This is tricky to deploy because you are no longer deploying yours from the cfg folder but a pre-created one.
And lastly- if you want access to NI's proprietary information you should contact them in a less public manner.  Just saying.
Hope this helps,
jigg
CTA, CLA
testeract.com
(4,014 Views)
jiggawax gave a really great answer. Just to reiterate, depending on what your doing, using the API is the best option. Other than jiggawax's link, this is the best information I could find about the TestExec.ini. But if you are looking for specific information about one of the .ini calls, creating a service request would be the best option for this. Keep in mind, a lot of the information in the configuration files is proprietary.
Steven Anderson
Applications Engineering
(3,999 Views)
Thank you for the information, part of the problem which you have enlightened for me is the fact that this file is auto created and is a system file. This makes so much more sense now... Thank you a bunch for your thorough response. Great Job!
(3,995 Views)
