NI TestStand
TestStand Batch model socket active
I need to be able to tell which sockets are active in Batch mode for a test I  am doing for eight units. I am having a hard time extracting the active socket with out pulling the whole array over and striping out the index. Is there an easier way to do this?
(3,288 Views)
I believe what you need is the value available in RunState.TestSockets.MyIndex variable. This variable will tell you which test socket index (zero-based) is currently active.
If I am misunderstanding your question, let me know and I'll be glad to look into this further.
Matt M.
(3,267 Views)
