NI TestStand
TestStand File Diff and Merge Utility
I can no longer find the utility in my TS 2016 Sequence Editor Toolbox. It doesn't present itself in the Package Manger ort the Repair tools.
I was just using it on the same laptop a couple months ago.
(1,817 Views)
Accepted by subsolanus
Guess you won't really find it in the NI Package Manager, since "real" NIPackages weren'tused before IIRC 2019.
Nowadays, the DiffMerge Tool resides under "C:\Program Files (x86)\National Instruments\Shared\TestStand\FileDifferLauncher.exe"
You might want to check, if this or a similar folder / exe exists on your PC.
Otherwise you might want to try to download the 2016 installer from the NI Website and run this one to try...
Good Luck!
(1,797 Views)
It's not there or anywhere on my HD.
I did a repair on my installation since I used it last and maybe it didn't make it.
Thanks for your reply!!!
(1,763 Views)
