NI TestStand
TestStand Menu (Source Control)
Is it possible to use Source Control for TestStand Sequence and i am not using TestStand Workspace
(5,545 Views)
Yes!
Use your SCC (Source Code Control) to check it in and out and treat it like any other binary file.
The only thing using a workspace gives you is the ability to check it in and out from TestStand.  However, this is not necessary to use SCC.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,542 Views)
Hi jigg,
Currently i am working only on TestStand Sequence but Source Control Menu items are disabled. How to map my source code which is in clearcase to make checkin and checkout possible from TestStand Itself
(5,519 Views)
Please read jigg's post again. You cannot do what you want to do without a workspace.
Hope it helps.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(5,508 Views)
Which menu items are disabled?  I don't understand which ones you are talking about.
jigg
CTA, CLA
testeract.com
(5,493 Views)
 Hi
Please find above snapshot , which i am refering about.
(5,474 Views)
That menu only works with workspaces and files inside of workspaces and projects.  However, you can still use SCC with standalone sequence files.  You just have to use the interface that is native to your SCC.
jigg
CTA, CLA
testeract.com
(5,446 Views)
