NI TestStand
TestStand Object Reference strange behavior with LabVIEW Module
Hi to all
I have a strange behavior with a LabVIEW Module which I use in a Subsequnce and use an Object Reference for Value passing.
I have created an exmaple to demonstrate the behavior.
I have the "MainSequence" in which I call three times the Subsequence "GetRandomNumber":
As Paramter I use an ObjectRefrence:
In the "GetRandomNumber" Subsequence I call a LabVIEW Module and assign its Output (a Variant) to the ObjectReference:
The strange behavior is that I get three times the same RandomNumber in the ObjectReference. It seems something strange with the ObjectReference.
I have alos added a direct call of the LabVIEW Module and assign its Output to the ObjectReference:
With the direct call of the LabVIWE Module I get three Times a different Value in the ObjectReference
What I'm doing wrong?
(154 Views)
Disclaimer: I haven't looked at the code you have attached
Just for the sake of completeness, there is a random function in TS also, so unless you need something very fancy here 😉
What you are describing sounds odd! Do you get the expected (three different) results, if you set the ObjectReference to Nothing  in between the sequence calls?
(131 Views)
Hey Oli, thanks for your reply
I just use the Random function to ilustrate my Problem.
I already tried to set ObjectReference to Nothing in between the sequence calls but without a effect.
Does somebody has an Idea what I'm doing wrong?
Best regards
(32 Views)
OK, I took a look at your code and I can confirm the behaviour as described.
The Parameter of the SubSequence is updated within the SubSequence, confirmed using single-stepping and checking the variables pane.
Nevertheless, the Local (in the caller) assigned to the SubSequence-Parameter is only updated for the very first call.
Since I haven't seen this issue with other data types than variants, my gut feeling is, that this has to do something with the variant itself.
It smells like a bug to me.... I'd recommend contacting NI Support! They should be able to work with the information you have collected
(26 Views)
