NI TestStand
Teststand change step name and save it
Hi All,
I know how to change the name of a step during execution of a sequence dynamically. However I want this name to be saved in the sequence file and not only changed during runtime.
Fyi: I have to automatically add numbers to step names for error logging purposes.
Is it possible to save these new step names?
(3,190 Views)
Hi Nick,
you need to save it to "RunState.SequenceFile.Data.FileGlobalDefaults".
Best regards
J. Ludwig
(3,152 Views)
Thanks for your help, however I don't see how I can save step names into "RunState.SequenceFile.Data.FileGlobalDefaults".
I used Fileglobaldefaults once, but it was to save variables permanently in the sequence file.
So please could you explain this further?
Thanks.
(3,150 Views)
Accepted by Nick1991
Hi Nick,
sorry for not being specific enough. Also I took a wrong turn in writing "FileGlobalDefaults"...
I just created a new sequence, adding one "Action" step and navigated to it:
RunState.SequenceFile.Data.Seq["MainSequence"].Main["Action"]
Then, with the TeststandAPI shown, I can get this:
RunState.SequenceFile.Data.Seq["MainSequence"].Main["Action"].Name
If you save the new string here, it should be kept, even after the execution ends.
I hope now it works. 😉
Edit: Of course you should reference to the steps you want to change by number, not by name as obviously calling them by name wouldn't work.
Best regards
J. Ludwig
(3,146 Views)
Thanks, this was where I was looking for…
(3,143 Views)
