06-23-2009 12:30 PM
06-24-2009 02:12 AM
LU_SDRON -
This is a know issue that has not been fixed or scheduled for fix, but we are tracking the issue internally with ID #48979. We are not aware of any workaround other than restarting the application. This issue only occurs when changing the theme while the application is running. Do you expect the users of your UI to be changing themes often?
06-24-2009 08:32 AM
Although I do not expect this to be a frequent occurrence, I want the best piece of software I can reasonably achieve. Since I know how to handle these messages myself, I will probably replace your control with my own based on Microsoft's status bar. Unless this will be corrected in the next release of TestStand I will replace it.
Thank you.
06-25-2009 12:50 AM
LU-SDRON -
We are not planning on fixing this cosmetic issue in the near future.
