Timed Loop?
A simple question that got me stuck for hours.
How do I make a timed loop in TestStand? The loop includes a few steps, and each loop should take x second.
Message 1 of 9
(9,422 Views)
Accepted by Bladhart
Hi Bladhart,
Try this example
Note this is a timer with a second range not with milliseconds !
Hope this helps
Juergen
=s=i=g=n=a=t=u=r=e= Click on the Kudos button (Gold Star) and see what happens =s=i=g=n=a=t=u=r=e=
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 9
(9,401 Views)
Is there a way to do (ms) range?
Message 3 of 9
(9,379 Views)
Hi Bladhart,
Try using the WIN API GetTickCount()
http://msdn.microsoft.com/en-us/library/ms724408.aspx
--Signature--
Message 4 of 9
(9,358 Views)
Hi Bladhart,
Try this example
--Signature--
Message 5 of 9
(9,356 Views)
Juergen,
I'm curious why you thought your original example only has 1 second resolution? The Seconds() function has 1 msec resolution.
Message 6 of 9
(9,347 Views)
Hi Dennis,
because i dont set a break point and watched the variables Vaule 🙂
The manual on SecondSinceStartup said nothing on ms.
And on the ExpressionBrowser on Second() i dont read the hole part.
But now i did it.
So thank you Dennis for pointing out that resolution is ms
I wish you and all other members out there
a happy new year 2009
juergen
--Signature--
Message 7 of 9
(9,268 Views)
Can you please tell me a program that opens .seq files?
Message 8 of 9
(8,769 Views)
TestStand obviously. Why would you hijack this thread for your question? Are you even sure you need to open a TestStand sequence file?
Message 9 of 9
(8,763 Views)
