Unknown variable or property name
I just opened a .seq created under teststand 2015 with teststand 2019 and when i want to run it I have errors like:
"Unknown variable or property name 'Parameters.ResultList [Locals.LoopIndex] .TS'."
Did I misconfigure teststand or whatever.
Thank you
Bestregards
Guillaume
(3,172 Views)
Accepted by Guillaume_92
You can create the Variable with the same Name and Same datatype.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,103 Views)
Hello and thank you for your answer.
I don't understand how I could lost these variables just by opening it with the 2019 version.
Best regards
Guillaume
(3,091 Views)
