NI TestStand
User Expression To Specify File
When editing the Source tab of the Property Loader there is an option to "User Expression To Specify File". This is what I want to build:
"C:\_views\AutomatedTests\" + FileGlobals.BoardType + ".txt".
How would one compose this into a usable expression?
thanx,
jvh
(3,369 Views)
Accepted by jvh75021
"C:\\_views\\AutomatedTests\\" + FileGlobals.BoardType + ".txt"
This should work...
Sathish
(3,354 Views)
Thanks.
Interesting that with the top radio button where you specify an absolute path single backslashes are OK but with the lower button where the adress is calculated doubles are required.
(3,342 Views)
