12-03-2020 01:08 PM
I am working on updating the Username in a the Status Bar, using the native ActiveX status bar. When I set a default username, I dont see the status bar updating.
Set the Username
Pane is configured as "User"
Status bar configured using the example from the Full Featured example.
Do I need to do anything else to update the Status Bar?
Solved! Go to Solution.
12-03-2020 03:47 PM
I figured out the issue, I has not starting the application manager. Once I added the "Start", the username updated.
