12-02-2010 01:31 PM
I need to use TestStand (4.0) to save and test some data that is input by the user/operator. This will be done before the TestStand program is started
to run the automated tests. It will be in a separate sequence before the automation is started.
There are 7 static resistance measurements that need to be taken by hand and then input into TestStand. This data will then be checked with a multiple numeric limit test to determine if the measurements pass or fail.
What would be the easiest way to do this? With a Message Popup? Or something else?
12-02-2010 10:36 PM
Hey Matrix007,
A couple things: Do they have to do this every time they run a test? Or is it done once a day or maybe once a month or something?
If it's done every time they run a test then here's a couple options:
1- Use a message popup in the preuut callback and store the info in a file global.
2- Instead of a message popup you can have a code module (either LabVIEW or CVI or something) with a GUI that is customized the way you want it. It can have inputs for the user and then pass those back into TestStand.
If it's done once a day or maybe once a month or something:
1- Create your own entry point in the process model. This will give them the option to run that from the OI. Then in there put a model callback and in your sequence override that with the popup or code module. Once that data is entered store it to a file (property object file or txt file). Then when the sequence runs it can read in the file and parse the info.
2- Just have them open a txt or csv file and manually change the values in there. Then read that file in your sequence when they run the test.
Just some thoughts,
12-17-2010 10:53 AM
Thanks for the reply. I just added 7 numeric controls to the Labview front panel and sent them to a 1D array.
I didn't think it would be that easy but it was.
